I have a problem with GURU Pro, I can't upload courses images. I get this message : Image is too large, maximum file size is 0.1kB.
Where can I change guru max file size upload?
Thanks for your help
The size can not be increased from Guru, this should be done from CPANEL, also, you can provide us site administrator and FTP account and I will do a debug in Guru upload files, maybe there is something wrong.
Kind Regards, Alin
Hi Alindinca,
In my CPANEL the size is 256M
With joomla media, I can upload images
I have the problem in guru pro -> Courses -> images
OK for my ftp and admin access
Thanks for all
loic-voisine-gmail-com Hi The FTP details are not working, kindly check and fix it.
Also check /images/stories/guru folder exist and has the permission to upload the files.
When Guru upload images the size calculated is the minimum value between "upload_max_filesize", "post_max_size" and "memory_limit". On your server the "memory_limit" value is -1, you can check on "System Information" - "PHP Information" page. I added in these files - "administrator/components/com_guru/controller.php" and "components/com_guru/controller.php" this line: ini_set("memory_limit", "256M"); You need to do a back-up to these files before update or you can update Guru to the next version and then you can add this line in both files.
Hello Alin
Thank you for everything, it works!
I keep these files
Thank you, have a nice day
