Hi, thank you for you answer. The three points are not resolved, are the same or worse than they were before. If the problem of the field "Capcha" has no solution and is very limited to adjust the field width, then because if I use any other template, or third party component with the same "Google Capcha" works well, and only in this template does not work ?, For example, here works well: https: // www. .com / contact-us.html
* In addition to the points already exposed a thousand times, I remind you that all these fields have even more problems in PC browsers, the 100 meter long fields of view from one side of the screen to the other and not the right size, like all the registration fields of any template.
** I need a professional solution to the problem, I do not have time to waste writing thousands of words and making screenshots of problems that you know better than me ...
best regards,
Michael. aman204
