mkoepf1 Hi Susanne
Kindly check now as I have created "hidden" menu item by toggling Display in Menu to No in link type sub-tab for specific menu item titled "Speaker" and assigned menu item type for specific article as seen in screenshot
Specific intro image can be clicked in order to see the article redirection. Ref: Screenshot
Thereon, You can assign respective modules to the created "hidden" menu item in menu assignment option and add further "hidden" menu items for other articles/categories which are being fetched in S5 masonry module however, don't have menu items added
Also, As apparently seen, The functionality to redirect to Link A if entered, isnt extended currently as the link for specific article will be redirected from intro image and text being fetched
For extending this functionality, Will report this with JA Dev. Team so as to be put up for consideration in future version releases depending upon the complexity and other parameters as the same can improve specific module's usability, stability and scalability
