bajer Friend
bajer
- December 2013
December 6, 2013 at 9:40 am #192776I have two clean installation from package jatc_t3v2_blank_j31.zip (version 13-09-2013)
http://www.joomlart.com/forums/downloads.php?do=file&id=3405
Joomla 3.1.5 in this packageFirst site – installed with sample data – default installation – TAGs working well – no problems with adding, saving, modify current tags…
Second site – installed without dample data – default installation – TAGs not working. Errors like:
Save failed with the following error: exception 'UnexpectedValueException' with message 'TagsTableTag::_getNode(1, ) failed.' in /var/www/puritybee/libraries/joomla/table/nested.php:1459 Stack trace: #0 /var/www/puritybee/libraries/joomla/table/nested.php(755): JTableNested->_getNode('1') #1 /var/www/puritybee/administrator/components/com_tags/tables/tag.php(181): JTableNested->store(false) #2 /var/www/puritybee/administrator/components/com_tags/models/tag.php(330): TagsTableTag->store() #3 /var/www/puritybee/libraries/legacy/controller/form.php(692): TagsModelTag->save(Array) #4 /var/www/puritybee/libraries/legacy/controller/legacy.php(722): JControllerForm->save() #5 /var/www/puritybee/administrator/components/com_tags/tags.php(22): JControllerLegacy->execute('apply') #6 /var/www/puritybee/libraries/legacy/component/helper.php(355): require_once('/var/www/purity...') #7 /var/www/puritybee/libraries/legacy/component/helper.php(335): JComponentHelper::executeComponent('/var/www/purity...') #8 /var/www/puritybee/administrator/includes/application.php(165): JComponentHelper::renderComponent('com_tags') #9 /var/www/puritybee/administrator/index.php(70): JAdministrator->dispatch() #10 {main}
What’s wrong on installation without sample data?
Saguaros ModeratorSaguaros
December 9, 2013 at 8:40 am #514754Hi bajer,
It looks like the error comes from base file of Joomla, please try to switch to default template from T3 Blank to a standard template of Joomla. If problem still persists, then its a error with Joomla version you’re using. Otherwise, its error of our template.
Please give it a try.
bajer Friendbajer
- December 2013
December 9, 2013 at 1:11 pm #514792Hi Saguaros,
The same errors with Protostar and Beez3 templates. How to solve the problem?
Should I upgrade to the latest version of Joomla 3.2? Purity II is compatible with the latest Joomla?
December 10, 2013 at 2:25 am #514882So there must be problem with Joomla package you used to install, please try to download new package and install again. If problem still persists, you should raise the same thread into Joomla forum, community there will help you.
<blockquote>Should I upgrade to the latest version of Joomla 3.2? Purity II is compatible with the latest Joomla?</blockquote>
Nope, sir. This JA Purity is not ready for Joomla 3.2
bajer Friendbajer
- December 2013
December 10, 2013 at 10:21 am #514943I have installed Joomla 3.1.5 from your package (JA T3v2 Blank for Joomla 3.1 (11.67 MB) quickstart 09-13-2013).
Please provide me link to your good (verified) package with “JA T3v2 Blank for Joomla 3.1”p.s. How to install/reinstall a good version of Joomla 3.1.5 on a faulty version of Joomla 3.1.5 without losing existing data?
How it is possible, that quickstart with no example data has bad Joomla 3.1.5 and quickstart with sample data is ok (Tags are working weel)? Joomla version is the same in both installations…
bajer Friendbajer
- December 2013
December 10, 2013 at 10:40 am #514946<em>@Saguaros 401278 wrote:</em><blockquote>Nope, sir. This JA Purity is not ready for Joomla 3.2</blockquote>
Is it ready for version 3.1.6?
December 11, 2013 at 3:58 am #515053You can download here:
http://joomlacode.org/gf/project/joomla/frs/?action=FrsReleaseBrowse&frs_package_id=6736
http://joomlacode.org/gf/project/joomla/frs/?action=index
I think version 3.1.6 is not much different from v 3.1.5, you can give it a try and if there is any problem, please let me know.
bajer Friendbajer
- December 2013
December 13, 2013 at 12:37 am #515288<em>@Saguaros 401278 wrote:</em><blockquote>So there must be problem with Joomla package you used to install, please try to download new package and install again. If problem still persists, you should raise the same thread into Joomla forum, community there will help you.
Saguaros,
Is it ready to Joomla 3.2.0 now? I see new tittle for download category http://www.joomlart.com/forums/downloads.php?do=cat&id=361 :
Downloads -> JA T3 Framework -> T3 Framework 2 for Joomla 2.5 & 3.2(2012 version)Anyway I don’t see any new packages… so are they compatible with new Joomla 3.2.0 ? Can we upgrade 3.1.5 to 3.2.0?
December 13, 2013 at 2:27 am #515294<blockquote>Downloads -> JA T3 Framework -> T3 Framework 2 for Joomla 2.5 & 3.2(2012 version)</blockquote>
Yes, we released new version of JAT3 framework 2 and JAT3 Blank template for J!3.2 yesterday, however, JA Purity is till undergoing testing.
Please check the new packages in above download link: http://prntscr.com/2aqxai
bajer Friendbajer
- December 2013
December 13, 2013 at 8:19 am #515329Very nice Saguaros but please let me know, how to update my current site with JAT3 V2 and JAT3 Blank template for J!3.1.5 to the latest version J!3.2? Should I use the updates installer (manager) from backoffice? I want to test and verify new version.
December 13, 2013 at 9:25 am #515333With our products (templates/extensions), please use our JA Extension Manager (JAEM) component to update (Backend > Components > JA Extension manager). Always take a backup of your site before updating (just in case).
bajer Friendbajer
- December 2013
December 13, 2013 at 10:46 am #515358No problem with template ja_t3_blank upgrade – succesfull
There is a problem with upgrade JA T3 Framework
Check update -> New version found!
– 2.6.9 [New! 2013-12-12]On click “Upgrade now” it return error:
500 – Internal Server ErrorIn my Apache error.log i have found info, that it was a problem with permissions – root only for few files. JA T3 Framework -> Successfully upgraded to version 2.6.9. Please refresh this page to see the version update.
bajer Friendbajer
- December 2013
December 13, 2013 at 3:16 pm #515377<em>@bajer 400816 wrote:</em><blockquote>I have two clean installation from package jatc_t3v2_blank_j31.zip (version 13-09-2013)
Second site – installed without sample data – default installation – TAGs not working. Errors like:
What’s wrong on installation without sample data?</blockquote>
This is a solution for JAT3 Blank and Purity II J! 3.1.5 installation without sample data (package jatc_t3v2_blank_j31.zip version 13-09-2013):
After install the TAG table is empty and you need insert first data to the table (you can use phpmyadmin to run sql query):
INSERT INTO `abcde_tags` (`id`, `parent_id`, `lft`, `rgt`, `level`, `path`, `title`, `alias`, `note`, `description`, `published`, `checked_out`, `checked_out_time`, `access`, `params`, `metadesc`, `metakey`, `metadata`, `created_user_id`, `created_time`, `created_by_alias`, `modified_user_id`, `modified_time`, `images`, `urls`, `hits`, `language`, `version`, `publish_up`, `publish_down`) VALUES
(1, 0, 0, 43, 0, '', 'ROOT', 'root', '', '', 1, 0, '0000-00-00 00:00:00', 1, '{}', '', '', '', 0, '2011-01-01 00:00:01', '', 0, '0000-00-00 00:00:00', '', '', 0, '*', 1, '0000-00-00 00:00:00', '0000-00-00 00:00:00');Important: abcde_tags it is example table name so you need change it to the proper suffix instead “abcde”.
Now you can add and edit new tags.
1 user says Thank You to bajer for this useful post
This topic contains 13 replies, has 2 voices, and was last updated by bajer 10 years, 4 months ago.
