1. [New Release] January Responsive Joomla template - JA Hotel >>> [ Info ] <<<
    [New] JoomlArt launches Custom Support services >>> [ See Details ] <<<
User Tag List
Closed Thread
Results 1 to 9 of 9
  1. #1
    Administrator Hung Dinh's Avatar
    Join Date
    Apr 2006
    4,343
    Points
    283,580.97
    Downloads
    6437
    Uploads
    3087
    Mentioned
    8 Post(s)
    Tagged
    1 Thread(s)
    JA Animation Module Installation Guide
    JA Animation module lets you enable image animation on your Joomla! site, rich backend with advanced features for nice effects and easy configuration.
    Step 1: Installation
    You follow simple steps below:
    1/ Install the module via Joomla Installer
    2/ Assign module to the position as you want
    3/ Enable the module
    Note:
    • Module Zip size is over 2 MB and the module will not install, until your PHP default upload setting ( 2MB ) is increased.
    • In some cases, the animation in user browser may increase the user side CPU usage.
    • Keep your module updated with the latest version
    Then, the module is instantly available in your front-end. If you are new to this stuff, follow detailed guideline below:
    ----How to install Joomla module
    Step 2: Configuration
    From the back-end of your Joomla site (administration) select Extensions->Module Manger, then click on module title JA Animationto enter configuration panel:
    Module Parameters:
    • Module Class Suffix: A suffix to be applied to the css class of the module(table.moduletable), this allows individual module styling. If first of anim module needed set module class suffix = ''_jaanim''
    • Select Animation Profile: Choose the animation profile you would like to show on the frontend. Each profile has optimized settings for best results.
      You can clone and edit the animation profile as per your need. Select profile and click Clone to customize it. Any way the default settings for that specific profiles are always available as reference for you.
      You can also delete profiles, however, there is no undo for this and you would need to reinstall the module or replace the default profile files in the ../modules/mod_jaanimation/profiles/
    Image path and Dimesions:
    Parameters Explanation:
    • Image Url: Default image set can be found at ..modules/mod_jaanimation/assets/images/ choose one of them or add yours there
    • Zindex: You can assign each element a number (z-index). The system is that an element with a higher number overlaps an element with a lower number. Change this only if your animation image or tooltip hides behind other elements of your site.
    • Width: Set width of image
    • Height: Set height of image
    Animation Settings:
    • Direction: Choose direction for animation
    • Move Type: choose animation movement pattern
    • Radius: Radius (apply for move type = sine) @exm: radius = 30
    • Preset Position: Preset position: array of many nodes (x,y)
      Exm: (100,200)(300,50)(500,200)
    • Delay: Step delay: delay time beetween of animating to a position
    • Origin Pos: Origin Position (X:Y)
    • Begin Pos: Begin Position (X:Y)
    • End Pos: End Position (X:Y)
    • Repeat: Choose how to Repeat the animation pattern.
    • Speed: Moving speed in px/s.
    • Use Multi Frame Images: Yes/No option to use multi frame images. This will work only with multi-frame images such as flying Pumpkin which consists of over 45 frames, shown in rapid sucession to create the flying pumpkin effect
    If select Yes option
    • Frame Size: while creating multi-frame images use fixed frame size. Enter the frame size value here.
    • Frame Items: Number of frames in the Multi-frame image.
    • Frame width: Width for each frame (when use multiple frame image )
    • Frame Order: If the frames in your images are set vertical, then choose vertical. If your image frames are horizontal, choose horizontal here.
    • Change Speed: Set frame speed in milliseconds
    Tooltip settings:
    • Show description: Show tooltip on mouseover on the animated image.
    • Tooltip offset : Tooltip offset (X:Y)
    • Description Parameters: Limited HTML support
    Screen and Image position settings:
    • Set Module Position:
      If set to absolute with the module position, the animated image would only be seen within the assigned module position and is in the focus of the user screen.
      If set Absolute with the page: the animated image will be animated across the whole page as defined in the animation settings. Unlike above it will NOT be restricted to the module dimensions.
      If set Absolute with User Screen: The animated object will auto scroll and stay in focus on user screen.
    Advanced parameters:
    See how it works in demo site:
  2. #2
    Licensed Member Expired
    Joomla Developer Membership - Renew 1 year Expired
    Join Date
    Apr 2010
    Location
    Czech Republic
    71
    Points
    497.38
    Downloads
    3661
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    nice tutorial, thanks
  3. #3
    JA Job Board [Professional] [JA Job Board Component] ExpiredJoomla Extensions Club - 1 Year ExpiredJoomlaTemplate Club Member - Personal License - Renew 1 Year Expired
    Join Date
    Apr 2010
    71
    Points
    328.03
    Downloads
    515
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If this module work with other JA templates ? for example JA Social ?
  4. #4
    JA Job Board [Standard] [JA Job Board Component] ExpiredJoomlaTemplate Club Member - Personal License - Renew 1 Year Expired
    Join Date
    Nov 2009
    82
    Points
    621.92
    Downloads
    186
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you for module!
    I've one question regarding the this module. I've set snow animation for my website. But it snows as 1 image . How can i make this animation be like snowing 100 snows?
  5. #5
    JoomlArt Support Member JA Developer's Avatar
    Join Date
    Nov 2008
    Age
    29
    8,034
    Points
    14,285.37
    Downloads
    2664
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lucky93 View Post
    Yes, you can use this on other templates. This module is integrated in JA Events as complimentary extensions so that it might be restyled to fit yours.
    Please click "thank you" button when get right answer from others.
    If your problem has been solved find the best answer and click (Mark Best Answer)
  6. #6
    Join Date
    Nov 2008
    Age
    29
    8,034
    Points
    14,285.37
    Downloads
    2664
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mastaliyev View Post
    In order to make 100 snows on your site, you have to create 100 animation modules and this seems be impossible as it will cause your computer pending...
  7. #7
    Join Date
    Nov 2009
    82
    Points
    621.92
    Downloads
    186
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so,how can i use snow animation then?
  8. The Following User Says Thank You to mastaliyev For This Useful Post:
    jjwijman (01-15-2011)
  9. #8
    Licensed Member
    Joomla Developer Membership - Renew 1 yearJoomlaTemplate Club Member - Personal License - Renew 1 Year Expired
    Join Date
    Sep 2007
    24
    Points
    136.91
    Downloads
    394
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This may be traitorous , but Yootheme have a snow module that gets around the problem you describe.
    Can't remember if it costs anything, though.
    David
  10. #9
    Joomla Template Club Member - 1 Year Expired
    Join Date
    Jun 2011
    Location
    Philippines
    85
    Points
    185.19
    Downloads
    236
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    any chance of the Flying Pumpkin for halloween to work on a Joomla 1.7.2 install using JA Social template for J!1.7? Spent a whole day on trial and error and still can't make it work. :-/
    No chance for me to disable mootools as both Kunena and JomSocial require it. Thanks for whatever help anyone can extend.
Closed Thread
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Stop working on Weekend!X
If your Boss broke your Joomla template or extension and ask you to fix it today. Here is the immediate solution. Then leave your request on the right forum, we will be helping after the Weekend Happy hours
Our Happy Hours: Friday 18:00 - Monday 9:00
No working during happy hours. Keep calm and don't break anything.
